last person joined: 8 hours ago
MERAKI wired guest integration with CPPM
This thread has been viewed 16 times
  • 1.  MERAKI wired guest integration with CPPM
    Posted Jan 07, 2022 10:00 AM
    Hello
    I've just setup NAC with CPPM on MERAKI switches. DOT1x and MAC-AUTH are both working. However if a device/user has a BYOD it need to be redirected to a guest VLAN with a landing page.
    Curently I wasn't able to set it up and looked on thousend sites to find something relevant.
    I would to heve a good how to manual or some help to set it up.
    Thx
    Jurgen Dendas
  • 2.  RE: MERAKI wired guest integration with CPPM
    Posted Jan 10, 2022 08:52 AM
    Hi, the only par that i've found is assign a guest vlan with some restricctions (walled garden) if 802.1x/MAB fails.
    You can find it here: How To: Integrate Meraki Networks with ISE
    Note.- The post is about integrating with ISE but just focus on the meraki part for wired authentication
    In order to know if it's possible to make a redirect to a splash/landing page I think should contact Meraki TAC and work with them.
    Hope this helps
    Ulises Cazares
