Merging 2 clusters of IAPs into 1 cluster
  • 1.  Merging 2 clusters of IAPs into 1 cluster
    Posted Jul 03, 2013 12:26 AM
    I am trying to merge 2 clusters in different subnet of IAPs into 1 cluster same subnet, the following is done in my lab
    Version 6.1.3.1-3.0.0.1
    AP-1 : Cluster 1 - SSID: Aruba-Testing1
    AP-2: Cluster 2 - SSID: Aruba-Testing2
    When I unplug AP-1 and plug it into AP-2 cluster it appears as part of AP-2 cluster broadcasting Aruba-Testing2 and forgotten about it's role as a Virtual Controller in cluster 1. Please advise if this is normal way an IAP will react when merging into another cluster? I was told that best practise is to reset the IAP first but in a deployed environment where the APs are mounted it is additional effort to bring it down and reset the AP. Any advise from the expert in this forum?:smileyhappy:
  • 2.  RE: Merging 2 clusters of IAPs into 1 cluster
    Posted Jul 03, 2013 12:47 AM
    This is expected behavior.
    The Virtual Controller of a group owns the config for the entire group.   When you join a new AP to the group, whether it is at factory default or has a config on it from a previous group, it will inherit the config from the VC of the group it just joined.
  • 3.  RE: Merging 2 clusters of IAPs into 1 cluster
    Posted Jul 03, 2013 01:24 AM
    Thanks Marcus, in this case I can save the effort of climbing up and down.
