Location Services
last person joined: 10 days ago
Location-based mobile app development and Bluetooth-based asset tracking with Meridian. Gathering analytics and business intelligence from Wi-Fi with Analytics and Location Engine (ALE).
meridian editor : what a "landmark" is ?
  • 1.  meridian editor : what a "landmark" is ?
    Posted Feb 13, 2017 10:22 AM
    Hi everyone
    i works with the meridian editor
    in the placemark's options, i can see a "landmark" option (see attached picture) landmark.PNG
    the documentation doesn't tell anything about what a "landmark" is
    does anyone know this feature ?
    Best regards
    Pierre
  • 2.  RE: meridian editor : what a "landmark" is ?
    Posted Feb 13, 2017 08:12 PM
    Hi Pierre,
    "LANDMARK" is an old property that was added to placemarks.  It is currently deprecated and not recommended for use any more.  It will be removed from a future version of the editor.
    Please use the LABEL property to name an area like "Engineering Dept" or "Lobby".
    Tim
  • 3.  RE: meridian editor : what a "landmark" is ?
    Posted Feb 14, 2017 02:31 AM
    Thank you Tim
    Can we say that "landmark" option for placemark is similar to "label" option for area ?
    Could you please post screen capture that shows each option ?
    Best regards
    Pierre
  • 4.  RE: meridian editor : what a "landmark" is ?
    Posted Feb 14, 2017 12:36 PM
    Hi Pierre,
    I updated my response from yesterday.  Can you explain what you are trying to accomplish and I will recommend the best approach?  Thanks!
    Best regards,
    Tim
  • 5.  RE: meridian editor : what a "landmark" is ?
    Posted Feb 17, 2017 05:46 AM
    Hello Tim
    it appears there is an anomaly in the way the android appviewer application displays the maps.
    Here are two screen capture for the same map.
    1) on an iphone
    The first one is on an iphone device and it is the result i want FOR THIS ZOOM LEVEL
    You can see only the
     - the "landmark" placemark (Restaurants)
      - the "label" area (Arènes)
    2) on an android (samsung galaxy)
    You can't see the landmark and the label
    you see lower level placemark instead
  • 6.  RE: meridian editor : what a "landmark" is ?
    Posted Feb 17, 2017 02:33 PM
    Hi Pierre,
    Yes, sometimes there are differences between the two platforms.  We try to keep the experience the same but the platforms themselves are simply not the same.
    Our team has filed a support ticket for you.
    Best regards,
    Tim
  • 7.  RE: meridian editor : what a "landmark" is ?
    Posted Feb 23, 2017 02:54 PM
    Hi Pierre,
    Our Meridian team has taken a look at your screenshots and determined that this isn't a bug. It's expected behavior for different devices to display the map differently. Even the same device with different resolution settings would display things differently.
    I hope this helps address your concerns.
    Cheers,
    Shawn
