Meru + ClearPass Guest
  • 1.  Meru + ClearPass Guest
    MVP
    Posted Jul 11, 2014 02:05 PM
    Running into a weird problem with a Meru and ClearPass Guest integration. I followed the Meru-ClearPass.pdf document and everything is working except when I log in with my credentials (after self-registering), i get redirected to "https://vpn/userLogin/" and I don't get logged in. This is defined in the NAS Login part of the Guest registration page. I also do not see any hits in access tracker. Any reason this would be happening? Hopefully somebody else has seen this.
    Thanks.
  • 2.  RE: Meru + ClearPass Guest
    MVP
    Posted Jul 11, 2014 03:14 PM
    update:
    If we add the exact URL with controller's IP address, the redirect works and everything is successful, however we then get redirected to this page:
    We do become authenticated and can browse away to get to the internet, but we should see a login success page.
    Also the variable {$h} seems to be causing a problem with reaching this page and becoming authenticated. That variable is located in the NAS Login section for destination url.
    Any ideas?
  • 3.  RE: Meru + ClearPass Guest
    Posted Nov 21, 2017 11:41 PM
    I have also see this exact same behaviour recently.  Were you able to find a resolution?
  • 4.  RE: Meru + ClearPass Guest
    MVP
    Posted Nov 22, 2017 09:54 AM
    This was quite some time ago, but I don't believe we ever resolved this. I think we had to go another route, but I couldn't tell you what that was.
