MESH between an Aruba AP 515 and a RAP 303HR
This thread has been viewed 19 times
  • 1.  MESH between an Aruba AP 515 and a RAP 303HR
    Posted Nov 20, 2020 02:51 AM
    Is it possible to MESH between an Aruba AP 515 and a RAP 303HR ? Or between 2 RAPs 303HR to have copper MESH connectivity? Are there any Wi-Fi and wired limitations?
    Arun Dev Singh
  • 2.  RE: MESH between an Aruba AP 515 and a RAP 303HR
    Posted Nov 20, 2020 07:34 AM
    Yes, you can create a mesh between AP 515 and RAP 303HR or between 2 RAP 303HR APs.
    One thing to realize is that for mesh the radio's (typical the 5GHz) will need to run on the same channel, which reduces the wireless capacity on that channel. Not sure what type of wired limitations you would think of, except of course that the wireless mesh link might have a slower connection speed and slightly more latency than a 1Gbps full-duplex wired connection.
    If you have urgent issues, always contact your Aruba partner, distributor or Aruba TAC Support. Check https://www.arubanetworks.com/support-services/contact-support/ for how to contact Aruba TAC.
  • 3.  RE: MESH between an Aruba AP 515 and a RAP 303HR
    Posted Nov 23, 2020 03:53 AM
    Thanks Herman :)
    Arun Dev Singh
