Mesh between IAP92(portal) and IAP105(point)
  • 1.  Mesh between IAP92(portal) and IAP105(point)
    Posted Apr 02, 2012 12:27 PM
    Having not dabbled with mesh on IAPs...
    I was wondering if you can mesh between IAP92 and IAP105 when the IAP92 is the portal?
    I'm aware that you cannot have an IAP as a mesh point and use the ethernet port but that's not what I'm doing here.
    James
  • 2.  RE: Mesh between IAP92(portal) and IAP105(point)
    Posted Apr 03, 2012 12:25 PM
    Aruba Instant supports MESH for the IAP-105; IAP-134 & 135.   It does not support MESH for the IAP-92 and 93.
    Here is some detail:
    1. Dual-radio only (i.e. IAP-105 )
    2. Over the air provisioning (active only when one Aruba Instant mesh network is being advertized, will not work for ROW version) and over the wire provisioning.
    3. Max hop count =2 (point->point->portal)
    4. Max number of mesh points per mesh portal is 8
    5. A mesh point cannot become the Virtual Controller
    Aruba Instant Mesh will not support LAN bridging or secure wired pass-through
    Hope this helps
