Mesh Config SoftWare
  • 1.  Mesh Config SoftWare
    Posted Feb 19, 2013 07:13 PM
    Does Mesh Config SoftWare manage MST200 ?
    i have  3 *  P 2 P connection ,  if i got Mesh Config Software will it be useful ?
  • 2.  RE: Mesh Config SoftWare
    Posted Feb 19, 2013 08:03 PM
    Yes!
    You can use it to visualize all the links, and it will give you near-realtime info on links and nodes.
    You can also do configuration with it including upgrades.
    -cl
  • 3.  RE: Mesh Config SoftWare
    Posted Feb 23, 2013 03:13 AM
    Thx , is this Software that is installed on Server ?
    how do i cpnnect to it ? using HTTP or dcetain client from PC ?
  • 4.  RE: Mesh Config SoftWare
    Posted Feb 24, 2013 06:31 PM
    It is a Windows application, that is accessed via HTTP.  You must use IE for it.
  • 5.  RE: Mesh Config SoftWare
    Posted Feb 25, 2013 06:06 AM
    is this software insatleld on any windows machine , or sepaarted one dedicated for it ? and whar are the SPecs needed ?
  • 6.  RE: Mesh Config SoftWare
    Posted Feb 25, 2013 11:01 AM
    Any windows machine.
    Nothing special for specs, it's not very resource intensive.
