Hi
I have a scenario with 3 x AP-375 that will be connected using mesh. They will be mounted on the roof of 3 houses lined in a row. The distance between both side APs (mesh point) to the center AP (which will be mesh portal) should not exceed 10m. All 3 APs are currently on 8.7.1.9 firmware version. The APs are intended to serve as backhaul only with each house having a switch and client APs forming a cluster across the mesh connection.
I have seen the post with instructions on how to configure mesh for AP-387. I have followed the procedure with just 2 x AP for testing purpose. I was unable to get the mesh point established with mesh portal after waiting for more than 15-30 mins. The LED on the mesh point would be steady red. When I execute the command 'show ap mesh neighbor' on the mesh point, it returns message 'mesh module is busy'. The following result returned when 'show ap mesh cluster status' was entered on the mesh point:
mesh cluster: enabled, mesh-cluster-name: <name>, mesh role: mesh point, mesh-split-5G: full range, mesh mobility: disabled. Similar result for mesh portal except the mesh role showed "mesh portal"
Configurations for mesh portal as follows:
standalone, extended ssid disabled, mesh-cluster-name, mesh-cluster-key, no mesh-disable, removed Setmeup SSID
Configurations for mesh point as follows:
standalone, extended ssid disabled, mesh-cluster-name, mesh-cluster-key, no mesh-disable, eth-0 bridging, eth-0 > meshprofile (admin UP, trunk mode native vlan 1, allow all, trusted), removed Setmeup SSID
I refer to the configurations for 8.7 user guide. Under the chapter for mesh, the above method is for standalone AP. There is a cluster-based configuration which I assumes the mesh portal and mesh point belongs to the same instant cluster. I have tried that as well using default profile but when I do a 'show ap mesh cluster status', the mesh-cluster is disabled.
Appreciate some advise and guidance here.
Thanks.
Simon Lim
