Mesh function of IAP275
  • 1.  Mesh function of IAP275
    Posted Apr 03, 2015 02:59 AM
    Hi,All
    I want to connect remote two spots by outdoor radio in Mesh.
    In IAP275, is mesh connection supported?
    When it is done, which version is it?
    When are you supported?
    I want you to tell me.
    Regards
  • 2.  RE: Mesh function of IAP275
    Posted Apr 03, 2015 07:40 AM
    It will be supported in the next version of code.
    Tim
  • 3.  RE: Mesh function of IAP275
    Posted Apr 03, 2015 08:27 AM
    Thanks a lot Tim !
