Mesh link down when transfer large file
  • 1.  Mesh link down when transfer large file
    Posted Nov 15, 2018 05:09 AM
    Hi
    Thank you all for the previous answers.
    2 - AP 274 (mesh portal 3X3-5712, mesh point 2X2-5314+terminator)
    1 - 7008 controller
    Distance between points 450 meters.
    I use to connect two wired networks.
    eth0 ports are connected to aruba 2530 (PoE mesh portal) and HPE 1920S switch.
    Mesh network is at work. SCADA system uses the network to receive data in small volumes.
    But I have a problem, when I try to transfer a large file (40-100Mb) between workstations, the mesh link down. Meesh point disappears. I need to wait when she again turn to the controller and get an ip address.
    Why it happens?
  • 2.  RE: Mesh link down when transfer large file
    Posted Nov 21, 2018 12:02 AM
    You will likely need to open a TAC case as that shouldn't happen. You would need to look at the AP and controller logs first to determine the reason why the APs are rebooting or why the link went down.
