Mesh on 2.4 GHz
  • 1.  Mesh on 2.4 GHz
    Posted Jun 30, 2017 04:12 AM
    Mesh with two IAP-277 on 5 GHz Band is unstable due to radar activity nearby.
    Is there a possibility to mesh on 2.4 GHz?
    6/28/2017 12:40:27 PM Target: AP01 Command: show ap arm history
    Interface :wifi0
    ARM History
    Time of Change Old Channel New Channel Old Power New Power Reason
    2017-06-28 11:36:00 116E 100E 30 30 R
    2017-06-28 11:35:08 100E 116E 30 30 I
    2017-06-28 10:58:14 116E 100E 30 30 R
  • 2.  RE: Mesh on 2.4 GHz
    Posted Jun 30, 2017 06:15 AM
    If this in instant, unfortunately mesh is only available on the 5ghz band.  Are you forced to use DFS channels because of your regulatory domain?
  • 3.  RE: Mesh on 2.4 GHz
    Posted Jun 30, 2017 06:21 AM
    Yes, Germany Outdoor
  • 4.  RE: Mesh on 2.4 GHz
    Posted Jun 30, 2017 07:09 AM
    Try to do 20mhz channels, instead of 80mhz channels.
  • 5.  RE: Mesh on 2.4 GHz
    Posted Jun 30, 2017 07:18 AM
    I am saying that because you could be seeing a false positive, and those are less likely to happen on 20mhz channels in my experience.
