Hi.
The "LAN mesh" and "remote mesh" options on my controller is greyed out.
My customer wants to use the Lan mesh wizard, so this is a problem.
What might be the cause of this being greyed out?
Tried this with version 6.1.3.7 and 6.1.3.4 with same result on both versions.
Thanks for any help!
There's not enough information in your message to really make a diagnosis.
Please open a TAC case and they can help you work through it.
Did you end up resolving this? I've got the same issue with a 3400 running 6.1.3.7
Yes, this case is resolved.
After speaking with TAC, they told me that Mesh LAN option is available in AP wizard only in ArubaOS 6.2 version.
So the solution to this issue is to to 6.2.
At least 6.2 is now General Availability :)
Thanks for the info!
TAC confirmed as well, they got back to me a couple of days later.
Scott
