Mesh Point and portal
  • 1.  Mesh Point and portal
    Posted Aug 08, 2018 05:20 AM
    Mesh point forms a mesh link with the portal. What is that link, is it an IPsec tunnel?
    Thanks in advance
  • 2.  RE: Mesh Point and portal
    MVP EXPERT
    Posted Aug 08, 2018 05:30 AM
    It can be either opensystem(no authentication or encryption) or wpa2-psk-aes (WPA2 with AES encryption using a preshared key).
  • 3.  RE: Mesh Point and portal
    Posted Aug 08, 2018 05:36 AM
    Thank you. I undertstand that the point authenticates with the portal through open system or PSK. The point speaks to the portal through a tunnel, Is that correct? what is the tunnel called? IPsec, GRE ?
  • 4.  RE: Mesh Point and portal
    Posted Aug 09, 2018 01:32 PM
    If you AP's are in Tunnel mode, there would be GRE tunnel between the AP and controller. Also could be IPsec but I believe you need an extended license along with an intentional config forIPsec. I would wager that this behavior is the same in Mesh mode as it is for wired modes.
    From the Aruba docs-
    Tunnel: The AP handles all 802.11 association requests and responses, but sends all 802.11 data packets, action frames and EAPOL frames over a GRE tunnel to thecontroller for processing. The controller removes or adds the GRE headers, decrypts or encrypts 802.11 frames and applies firewall rules to the user traffic as usual. Both remote and campus APs can be configured in tunnel mode.
