Mesh point reboots after connecting wired client
This thread has been viewed 49 times
  • 1.  Mesh point reboots after connecting wired client
    Posted Jul 02, 2021 04:30 AM
    i´m setting up an IAP 8.8.0.1 cluster. So far everything works and mesh works also. But now i have a problem: When i connect a client to one of the eth1-4 prots of my 505H, the mesh point reboots and won´t come up again, until i remove the client. Then it will reconnect over mesh to the cluster.
    I have assigned a new wired profile to eth1-4 to get independet from the default-wired-profile, but it didn´t help.
    Thanks and regards
    Daniel
    Daniel Ebling
  • 2.  RE: Mesh point reboots after connecting wired client
    Posted Aug 10, 2021 08:55 PM
    was this issue resolved?
  • 3.  RE: Mesh point reboots after connecting wired client
    Posted Aug 30, 2021 01:59 PM
    I have the same problem. I dug a bit and observed this message:
    "LAST REBOOT REASON: Mesh point transitioned to portal"
    Does anyone have any ideas?
  • 4.  RE: Mesh point reboots after connecting wired client
    Posted Aug 31, 2021 04:33 AM
    Looks like the AP is getting an IP address (DHCP/static) on the port where you connect your wired client. As soon as it detects a more or less functional uplink, it will transition in a mesh portal, IF you provisioned the AP as 'mesh auto'. To prevent this, provision your APs dedicated as mesh portal (connected to the wired) or mesh point (connecting wirelessly to a mesh portal).
  • 5.  RE: Mesh point reboots after connecting wired client
    Posted Aug 31, 2021 11:03 AM
    The device I am plugging in to Eth3 is an IP camera. It cannot act as a DHCP server. Anyway, I thought I could still try to provision the AP as dedicated mesh point, as you refer to, but cannot find this setting. I read through the Instant User Guide and cannot find a reference to it. Do you have further information?
  • 6.  RE: Mesh point reboots after connecting wired client
    Posted Aug 31, 2021 11:38 AM
    Sorry, I did not get the point that this is an Instant device. Mesh in Instant is always auto.
    Did you create a new wired network profile to assign to your eth3? With the uplink option disabled?
    What firmware version are you on? Have you tried to upgrade your AP to a recent firmware?
  • 7.  RE: Mesh point reboots after connecting wired client
    Posted Aug 31, 2021 12:05 PM
    Yes, like the OP, I created a new wired network profile. I assigned eth1-eth3 to it, and the uplink option is disabled. The firmware version is 8.8.0.1_80393. Thanks for the assistance!
  • 8.  RE: Mesh point reboots after connecting wired client
    Posted Sep 01, 2021 03:27 AM
    I checked existing tickets at Aruba Support, and could not find any. Please open a support ticket to get this investigated as it appears to be rare, and unexpected.
  • 9.  RE: Mesh point reboots after connecting wired client
    Posted Sep 15, 2021 08:34 PM
    I opened a ticket, worked with Support, and have a resolution. The engineer said "Kindly enable Eth0 bridging in the IAP which is acting as mesh point from central.". So, I went to Access Points > Uplink and changed Eth0 Mode from Uplink to Downlink. The AP did appear to reboot and then take a few minutes to mesh up, but once it did, my downlink device started communicating.
  • 10.  RE: Mesh point reboots after connecting wired client
    Posted Sep 16, 2021 03:07 AM
    Thanks for reporting back. That approach makes sense.
