mesh redundant portal
  • 1.  mesh redundant portal
    Posted Aug 06, 2014 09:24 AM
    I've got a point to multipoint configuration at a customer site and whent he main mesh portal goes down, another portal is supposed to take over.
    This is not happening. Once the main portal goes down, the entire mesh goes down and the redundant portal stays up. Where can I check this configuration? The system has worked in the past and just stopped working when upgrading from an old controller to a 7200.
  • 2.  RE: mesh redundant portal
    Posted Aug 06, 2014 10:02 AM
    Can you please share how you have this configured ?
  • 3.  RE: mesh redundant portal
    Posted Aug 06, 2014 10:23 AM
    I've included everything i think is relevant...
    ap mesh-recovery-profile cluster RecoveryCxXNI8gKXgR3fsvx wpa-hexkey "long encrypted key"
    crypto isakmp policy 20
      encryption aes256
    ap wired-ap-profile "CU-WAP-1"
       wired-ap-enable
       trusted
       switchport access vlan 20
       switchport trunk native vlan 7
    ap mesh-ht-ssid-profile "default"
    ap mesh-cluster-profile "default"
    ap mesh-cluster-profile "Cust_mesh_cluster_1"
       cluster "Cust_mesh_cluster_1"
       opmode wpa2-psk-aes
       wpa-passphrase 68147f72a233e02af9490f6fcad0c403fcce124d5544a31d
    ap mesh-cluster-profile "Cust_mesh_cluster_2"
       cluster "Cust_mesh_cluster_2"
       opmode wpa2-psk-aes
       wpa-passphrase 42bd0d6f0e8c10b381d744352ee2b7627130fdf0f95626dc
    ap mesh-radio-profile "Cust_mesh_radio_1"
    ap mesh-radio-profile "Cust_mesh_radio_2"
    ap wired-port-profile "CU-WAP-1"
    rf arm-profile "Cust_mesh_arm_profile"
       min-tx-power 127
    rf dot11a-radio-profile "Cust-max-arm-power-rp"
       channel 161
    ap-group "AP_Mesh_1_MeSh"
       virtual-ap "Cust_employee_vap"
       virtual-ap "Cust_device_vap"
       dot11g-radio-profile "Cust_mesh_g_radio_profile"
       ids-profile "Cust_ids_low"
       mesh-cluster-profile "Cust_mesh_cluster_1" priority 1
       mesh-cluster-profile "Cust_mesh_cluster_2" priority 2
    ap-group "AP_Mesh_2_MeSh"
       enet0-port-profile "CU-WAP-1"
       enet1-port-profile "CU-WAP-1"
       mesh-cluster-profile "Cust_mesh_cluster_2" priority 1
       mesh-cluster-profile "Cust_mesh_cluster_1" priority 2
  • 4.  RE: mesh redundant portal
    Posted Aug 26, 2014 01:51 PM
    bump?
    Do all portals need to be on the same channel?
  • 5.  RE: mesh redundant portal
    Posted Aug 26, 2014 02:10 PM
    They need to be on same mesh link channel on .11a
