Mesh setup of 2 AP375
  • 1.  Mesh setup of 2 AP375
    Posted 7 hours ago
    Hi guys,
    I thought i already started this but could not see any information so I thought I enter it again.
    I have 2 AP375
    This is what I want to acheive
    internet -> Switch -> AP375 (PORTAL) -> AP375 (POINT)
    both are running frimware 8.12.0.1_89864 (Digitally Signed Production build
    I belve I am folloing the steps correctly as detailed as I did havea nother system working before.
    plug both units to switch
    let them get IP address in same network
    turn Extended ESSID OFF
    disconnect one unit (the non controller unit)
    and plug it on with PoE only (no ethernet lan connection)
    what I was seeing was the AP that was to be a POINT was a Client on the controller/Portal AP?
    can someone please  shed some light on what is happening and what step am I  missing?
    Is the SW/firmware version wrong?
    Thanking you in advance
    Klime
    Klime Zengoski
    Communications Engineer
  • 2.  RE: Mesh setup of 2 AP375
    Posted 7 hours ago
    I also had trouble setting up a point to point connection.
    I used the folowing guide that helped me a lot:
    ​Met vriendelijke groet,
    Dion
    Vermeulen
    i‑LEVEL
    ICT Solutions B.V.
    +31 (0) 88 340 02 00
    dvermeulen@i-level.nl
    https://www.i-level.nl
