MESH with AP 175p Advice
  • 1.  MESH with AP 175p Advice
    Posted Aug 18, 2014 05:54 PM
    Hello
    If a client already own a few APS 175P and they want to do some mesh between them let say
    AP A to AP B  which has 1km
    What antenna you guys recommend?
    I really have not configured mesh for long distances so well i bealive that would be the antenna 5314 of 30 Degrees.   That would reach the 1 km? with no issues?
    Cheers
    Carlos
  • 2.  RE: MESH with AP 175p Advice
    Posted Aug 18, 2014 06:52 PM
    Check out our Outdoor 3D Planner.  It uses Google Earth to display Mesh links and client coverage models in 3D after compiling the information in the Aruba Networks planning tool.  The tool is free to use and you can model different APs and different antennas.
    I am attaching a training .ppt that should provide all you need to get started.
    Attachment(s)
  • 3.  RE: MESH with AP 175p Advice
    Posted Aug 18, 2014 08:03 PM
    Correct, the 5314 will be your best fit....
  • 4.  RE: MESH with AP 175p Advice
    Posted Aug 18, 2014 08:05 PM
    Thanks Marcus!
    Thanks Howard
    Howard do you know what would be the maximum distance for that antenna if we got line of sigh?? i mean having good Throughput, i mean full 300Mbps on 5ghz to be specific.
    Cheers
    Carlos
  • 5.  RE: MESH with AP 175p Advice
    Posted Aug 18, 2014 11:24 PM
