Mesh with IAP 275 quesstions
  • 1.  Mesh with IAP 275 quesstions
    Posted Dec 19, 2014 04:49 AM
    hi,
    I'm going to configure a mesh link with 3 IAP 275 and I Have some question:
    1. What is the average distance between two IAP (in open area).
    2.Can an IAP configured as a mesh point, bridge the signal to another IAP (another mesh point).
  • 2.  RE: Mesh with IAP 275 quesstions
    Posted Dec 19, 2014 09:08 AM
    Mesh isnt supported yet on the 275's
  • 3.  RE: Mesh with IAP 275 quesstions
    Posted Dec 19, 2014 10:26 AM
    Thank you for the replay,
    yes i just get the confirmation from Aruba TAC.
  • 4.  RE: Mesh with IAP 275 quesstions
    Posted Dec 19, 2014 10:32 AM
    For the refernce
     the IAP
    • 224 / 225
    • 274 / 245
    • 204 / 205
    • 214 / 215
    Do not support the Mesh yet , so be careful :)
    Regards
  • 5.  RE: Mesh with IAP 275 quesstions
    Posted Feb 05, 2015 10:39 AM
    Hi!
    From what I´ve heard the functionality should be available in Instant OS 4.2. Anyone have information about when it will be available?
  • 6.  RE: Mesh with IAP 275 quesstions
    Posted Feb 05, 2015 11:03 AM
    from what i've heard it is under test.
    there are no official date.
  • 7.  RE: Mesh with IAP 275 quesstions
    Posted May 11, 2015 12:44 PM
    Any updates? I choose Aruba radios over Ruckus because of their ability to be controller-less. Ruckus radios are mesh capable but with a controller.
  • 8.  RE: Mesh with IAP 275 quesstions
    Posted May 11, 2015 12:51 PM
    Mesh is currently available on the controller platform. Controllerless (Instant) is expected to be available by the end of June. Please contact your Aruba rep for more info.
    Tim
  • 9.  RE: Mesh with IAP 275 quesstions
    Posted May 11, 2015 12:55 PM
    Thank you Tim for the very quick reply.
  • 10.  RE: Mesh with IAP 275 quesstions
    Posted May 11, 2015 10:18 PM
    I logged a call to Aruba TAC to see when the wireless mesh fuction will available for the IAP-2xx series. From memory it was July. I had access to the beta and can confirm i have 2 x IAP-274s wirelessly meshed and working very well.
  • 11.  RE: Mesh with IAP 275 quesstions
    Posted May 21, 2015 12:52 PM
    are you using them strickly as a mesh backhaul or are you also using them as client coverage?
  • 12.  RE: Mesh with IAP 275 quesstions
    Posted May 21, 2015 01:51 PM
    for the backhaut and the covrage
  • 13.  RE: Mesh with IAP 275 quesstions
    Posted May 21, 2015 02:18 PM
    Nice. I am designing a large outdoor property with three IAP-275s, but need a bridge between two buildings.  Once these come in I will see what I can setup as far as the bridge/client coverage combination to confirm before implementation.  But for this design I will do what I know and put a separate PtP bridge in.
  • 14.  RE: Mesh with IAP 275 quesstions
    Posted May 21, 2015 03:41 PM
    Hi ,
    if you  want to do the mesh with AP 275 , you must use the ArubaOS 6.4.3.1 (or later).
    it is  sweteble to put the backhaul in the 5 Ghz Band .
    you can edit the Mesh Parameter in The APgroup>mesh.
    then you can provisione the AP with it's mesh role.
    Regards
  • 15.  RE: Mesh with IAP 275 quesstions
    Posted Aug 08, 2015 02:00 PM
    Instant 6.4.3.1-4.2 is now available in Early Deployment with mesh support.
    https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/EntryId/18363/Default.aspx
