I'm looking for the pro's / con's using a Mesh construction between 2 IAP205.
Can somebody tell me if I loose streams or do I loose a whole antenna? I know a Mesh will be performing less when connecting directly on a cable. I'm looking for a small solution in a house, cabling is an issue right now. So that is why I'm looking into Meshing
