Messages exchanges between SMS-Gateway and Clearpass
  • 1.  Messages exchanges between SMS-Gateway and Clearpass
    Posted Dec 16, 2016 12:22 PM
    I am new to Clearpass, not have much experience in Clearpass. I want to know, messages exhanges between SMS-Gateway and Clearpass to send credential to Guest by SMS.
    I am observing that few SMS are getting error and peoples are not getting SMS. We are using HTTP-Port  10003
    Kindly let me know following things:
    2. What are different errors occurs
    3. How to know, which is causing issues.
    Atif.
  • 2.  RE: Messages exchanges between SMS-Gateway and Clearpass
    Posted Dec 16, 2016 09:08 PM
    You should probably open a TAC case to get to the bottom of your specific issue.
  • 3.  RE: Messages exchanges between SMS-Gateway and Clearpass
    Posted Dec 17, 2016 02:06 AM
    Just for information: Once doing more troubleshooting, I observe that I am getting following error:
    Client: x.x.x.x
    Script: /guest/guest_register.php
    Function: NwaSmsSendMessage
    Arguments: array (
    'rtn' => array (
    'error' => 1,
    'message' => 'Unable to send message. Invalid Destination Address - 0xb',
    'options' => array (
    'auth_username' => 'Ixxxx',
    'auth_password' => '●●●●●●●●',
    'enable_debug' => true,
    'smpp_sys_type' => 'xxxxxx',
    'smpp_http_url' => 'x.x.x.x',
    'http_port' => '10003',
    'id' => '18',
    'category' => 'sms',
    Before opening a case, I want to done my complete troubleshooting. Kindly let me know, If you have any idea what error is this.
  • 4.  RE: Messages exchanges between SMS-Gateway and Clearpass
    Posted Dec 19, 2016 03:14 AM
    You're using Custom HTTP gateway? POST or GET?
    What happens when you test this directly from the gateway setup page? Check the "debug" box for more information when doing this.
    Get this to work before you test it from the registration page.
    Then verify that you are using the correct field for autosend_sms which by default is the "cellphone" field
  • 5.  RE: Messages exchanges between SMS-Gateway and Clearpass
    Posted Dec 19, 2016 04:13 AM
    Hi Joslb,
    I have done troubleshooting with help of TAC and we observe that there is no issue in Clearpass configuration. Took packet capture from Clearpass end for working SMS and non-working SMS.
    • From the packet captures we could verify the Clearpass was forwarding the SMS receipt without any difference for working and non-working SMS to test clients, but the SMS gateway was replying “invalid destination address’"
    Already asked Customer to troubleshoot this issue with SMS Gateway team
