Network Management
method to determine Ethernet speed of AP's?
This thread has been viewed 41 times
  • 1.  method to determine Ethernet speed of AP's?
    Posted Sep 22, 2014 11:57 AM
    I'm interested in searching for / exporting a list of AP's that are running at 100Mbps.  On my controllers I'm running v6.3.1.9, and Airwave is on v7.7.12.  Ideas?
  • 2.  RE: method to determine Ethernet speed of AP's?
    Posted Sep 22, 2014 03:30 PM
    1. You can find out from the switches where APs are connected
    2. You can run following command on controller where APs are terminating:
              show ap debug system-status ap-name <ap-name> | begin "Speed Settings"
              Output:
              Ethernet Duplex/Speed Settings
              Autoneg Speed (Mbps) Duplex Iface
              on           1000                Full     eth0  <<<<<<<<<<<<<<
              on           10                    Half    eth1
  • 3.  RE: method to determine Ethernet speed of AP's?
    Posted Sep 22, 2014 03:37 PM
    Unfortunately there's no way to dump a list out on the controller. As aalap22 said, your best bet is the upstream edge switches.
    Do you have your edge switches in Airwave? You may be able to get the speed there depending on the switch vendor.
  • 4.  RE: method to determine Ethernet speed of AP's?
    Posted Sep 22, 2014 04:01 PM
    Thanks for the replies, folks.  At this time we don't have our edge switches in Airwave.  Some of our switches are old 3com (rebranded HP) with little management capabilities, and we intend to replace those with Aruba S1500's next summer.  We have six Aruba Mobility Access switches (S1500's and S2500's) in place, and I'll add them to Airwave in the near future and see if the option to filter by Ethernet speed exists there.
  • 5.  RE: method to determine Ethernet speed of AP's?
    Posted Sep 22, 2014 04:03 PM
    On the Aruba switches, you can easily see which ports have access points on them (and see the AP name!) by running the "show neighbor-devices" command.
  • 6.  RE: method to determine Ethernet speed of AP's?
    Posted Mar 03, 2021 09:15 AM
    Hi there!
    Found this post 'cause we have 2800 APs, bus > 280 APs running suboptimal ethernet (and mesh).
    Now it's about 6 Years ago.
    Is there any change in Airwave?
    Cannot trigger all 2000 Switches of different types (Comware 3-7 and Aruba).
    So best would be, the reports will show me all APs with 100MBit/s or less...
    Can Airwave 8.2.12.0 do this now? Firmware AP303 8.7.1.1
    Regards
    Frank from LWL Muenster Germany
    Frank Cordes
  • 7.  RE: method to determine Ethernet speed of AP's?
    Posted Mar 05, 2021 03:47 PM
    You can run an Inventory Report with details about every device. There are columns for ethernet status in those details.
    Dan Comfort
  • 8.  RE: method to determine Ethernet speed of AP's?
    Posted Mar 10, 2021 03:19 AM
    Thank You !
    Works for me.
    Didn't worked much with reports, but had not found this option "Include details about every device: " earlier... Perfect reports are a little bit trickky, isn't it?
    Thanks!
    Works fine!
    Frank
    Frank Cordes
  • 9.  RE: method to determine Ethernet speed of AP's?
    Posted Apr 19, 2021 12:58 PM
    Hello @gg-airhead
    Use mentioned-below steps to determine the Speed of Ethernet;
    1. Open Settings.
    2. Click on Network & Internet.
    3. Click on Status.
    4. Under the "Change your network settings" section, click the View your network properties option.
    5. Under the "Properties" section, find the network adapter (Wi-Fi or Ethernet).
    6. Determine the connection speed in the Link speed (Receive/Transmit) field.
    Regards
    Sima Yrp
