last person joined: 10 hours ago
MGMT and Data Port in ClearPass
  • 1.  MGMT and Data Port in ClearPass
    Posted Aug 16, 2017 02:37 AM
    Hi Experts,
    Good Day!
    I would like to ask what are the traffic passing in the MGMT and DATA Port in ClearPass?
  • 2.  RE: MGMT and Data Port in ClearPass
    Posted Aug 16, 2017 04:00 AM
    Please check the Service Routing Technote, that is available from https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/7961/Default.aspx
    My personal advice would be to just use the management port, and only use the data port after you read and understood the Technote. ClearPass works fine with just a single interface, and having just one interface keeps your design simple in most cases.
    In short, when you enable both ports, all outgoing traffic will originate from the data-port, unless it is local for the management port subnet, or if there is a management route that can be set on the command-line only.
