AOS-CX Switch Simulator
mgmt int on newer versions of simulator don't work
This thread has been viewed 24 times
  • 1.  mgmt int on newer versions of simulator don't work
    Posted Jan 08, 2024 09:45 AM
    on ESXi 7.0 hipervisor
    But on all newer versions
    VM settings are the same in both cases
    Is this behavior bug or feature :) ?
    BR,
    Mladen
  • 2.  RE: mgmt int on newer versions of simulator don't work
    Posted Jan 09, 2024 04:55 AM
    I don't have this problem on EVE-NG, so I don't think it's the simulator. Just check your interfaces and connections to verfy you have it right.
    Arne Opdal
  • 3.  RE: mgmt int on newer versions of simulator don't work
    Posted Jan 09, 2024 06:08 AM
    VM deployment is relatively simple, it is like this for both versions of switches
    network adapter 1 is for mgmt int., as told in the educational video.
    BR,
    Mladen
  • 4.  RE: mgmt int on newer versions of simulator don't work
    Posted Jan 09, 2024 06:35 AM
    Just tested on VMWare workstation on my laptop:
    With bridged interface "Replicate physical nettwork connection state" must be checked:
    Vmware workstation 17.0.0
    Windows 11
    Arne Opdal
  • 5.  RE: mgmt int on newer versions of simulator don't work
    Posted Jan 09, 2024 08:50 AM
    unfortunately not exactly same environment, I have only ESXi.
    Mladen
  • 6.  RE: mgmt int on newer versions of simulator don't work
    MVP EXPERT
    Posted Jan 09, 2024 06:16 PM
    I agree with Arne, dont think ESX or EVE is the issue.
    I use ESXi 6.7U3 with latest AOS_CX simulator 10.13.0005.
    If you install the Simultator OVA direclty on ESXi make sure use the right virtual NIC by checking the mac-address in your simulator and vmware. I would recommend to use EVE-NG.
    Marcel Koedijk | MVP Expert 2023 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
