We are looking for a micro USB network adapter works well with the Aruba wireless. I checked the interoperability listing and did not see any. Does anyone know of one that has tested? Thanks.
May I ask why MicroUSB? You could get an adapter that converts MicroUSB to full size.
I meant a normal USB plug but the size of the device itself. I am looking for something that is about the size of the bluetooth adapter for a wireless mouse.
Is your plan to use these in desktops and you don't want the antennas?
Let me know how it goes, there is not much internal WLAN nics in the 5ghz range for desktops.
-Thanks.
