Microsoft Lync
  • 1.  Microsoft Lync
    Posted Oct 23, 2013 04:36 PM
    Hello, The compatibilite of Microsoft Lync, depend on controller? Access Point? Firmware?.
  • 2.  RE: Microsoft Lync
    Posted Oct 23, 2013 05:07 PM
    If you want the Microsoft Lync API the controller needs AOS6.3.1.x
    It is supported on any of the AP supported under 6.3.1.x
    But you should be able to use Lync on AOS6.1.x
    http://www.arubanetworks.com/pdf/solutions/SG_DeployMicrosoftLync.pdf
     It is supported on any of the AP supported under 6.1.x
  • 3.  RE: Microsoft Lync
    Posted Oct 24, 2013 09:55 AM
    To be 100% clear :
    LYNC works on -ANY- Aruba infrastructure.
    It just works -BETTER- with the software releases indicated above.
    Better being defined as:   higher performance, additional visibility, ease of troubleshooting/operations
    JF
