The error is:
2019-06-23 17:09:36 [ERROR] [checkDBFiles] Restore all database failed: Components is not match
Which means that the components of IMC that were deployed when the backup was taken are not exactly the same as the components currently deployed on the system to which you are restoring. The components and their versions must be an exact match between both systems.
To figure out what doesn't match, compare the dbman.....conf file included in your original backup, and the one in the backup you took from the new system (it can be opened with a text editor). The components and their versions listed there must match.
In your case it looks from the error details like the issue is with aclm_db you are trying to restore. Could it be that this component is not deployed on your new system, or that the version on which you performed the backup was outdated?
You could fix it by either:
a) Undeploying or Deploying components on your current IMC system to match those in the backup
OR
b) Editing the backup's dbman....conf file to remove the reference to the non-matching component (aclm_db), saving it and then restoring all DBs except the one you removed from there.
Hope that helps.
