Migrated to Amigopod, CPU on Aruba controllers now crushed, reach 100% frequently
  • 1.  Migrated to Amigopod, CPU on Aruba controllers now crushed, reach 100% frequently
    Posted Feb 22, 2012 11:23 AM
    We recently migrated to Amigopod for our guest captive portal solution and noticed we were experiencing a lot of issues with Andriod devices and sometimes Firefox on laptops.  One obvious thing we see is that the Aruba controller that guests connect to, and is used for redirection over to Amigopod, is frequently pegged at 100% CPU, 90% of which is in the "user" part of show cpuload.  Also, when the CPU get's that high, we can't even SSH to the controller.
    show cpuload current shows the high CPU utilization is attributed to the httpd daemon, and the controller can spawn quite a lot of httpd processes as well.
    These are 2400 controllers running 5.0.4.4 and were previously used (for about four yesra) as our guest solution using the Aruba captive portal without issue.
    We have cases open with both Aruba and Amigopod, but wanted to see if anyone else has seen this or has any ideas.
  • 2.  RE: Migrated to Amigopod, CPU on Aruba controllers now crushed, reach 100% frequently
    Posted Feb 22, 2012 11:58 AM
    Mike,
    Were you doing HTTPS on the controller for CP before you moved it to Amigopod?
    Do a show web-server on the controller and post the results.
  • 3.  RE: Migrated to Amigopod, CPU on Aruba controllers now crushed, reach 100% frequently
    Posted Feb 22, 2012 01:02 PM
    Yeah, we were doing HTTPs with the old solution as well.
    Web Server Configuration
    Parameter                                      Value
    Cipher Suite Strength                          high
    SSL/TLS Protocol Config                        sslv3 tlsv1
    Switch Certificate                             GW_PORTAL
    Captive Portal Certificate                     GW_PORTAL
    Management user's WebUI access method          username/password
    User session timeout <30-3600> (seconds)       900
    Maximum supported concurrent clients <25-400>  25
  • 4.  RE: Migrated to Amigopod, CPU on Aruba controllers now crushed, reach 100% frequently
    Posted Feb 23, 2012 01:19 PM
    Just in case anyone finds this post in the future, a kernal change was made on our Amigopod server.  We were source PATing our guest IP addresses so they wouldn't be seen in the inside of the network.  That in itself caused some issues that caused the need for the tweak in Amigopod.
    We still don't know why the controller's CPU utilization is so high aside from the fact that it's the httpd processes that is causing it.
  • 5.  RE: Migrated to Amigopod, CPU on Aruba controllers now crushed, reach 100% frequently
    Posted Feb 23, 2012 01:44 PM
    The Amigopod setting is tcp timestamps. When tcp timestamps are enabled on the Amigopod, there are situations where this feature will cause slow access to the captive portal or no access at all (due to timeout). To disable it, you need to go into Administrator-System control-system config In the text box with all of the kernel options, copy/paste the following 2 lines:
    # Disable TCP timestamps
    net.ipv4.tcp_timestamps = 0
