Primary (K-12) Education
Got networking questions for schools or want to know more about E-rate? Submit them here!
Migrating from mschapV2 AAA authentication to eap-tls
  • 1.  Migrating from mschapV2 AAA authentication to eap-tls
    Posted 2 days ago
    Hello All in the education sector,
    Looking to migration from mschapV2 AAA authentication to EAP-TLS. Reason being District purchased new CX switches a few months back and planning on buying another 90+ on e-rate shortly however, CX models no longer have mschapV2 AAA authentication commands and this is a big problem.
    Would it be better to pay for upgrading the whole of the 292 switch environment to Clearpass, or doing the conversion myself to EAP-TLS?
    Environment:
    Procurves 2920s
    Aruba 5406zlr2
    Aruba CX (I forget the model)
    Windows NPS
    Windows Certificate Authority
  • 2.  RE: Migrating from mschapV2 AAA authentication to eap-tls
    Posted 2 days ago
    Not sure what you configured today for mschapv2 on your switch, and normally for aaa port-access you configure the EAP method (PEAP-MSCHAPv2 or EAP-TLS or TEAP) ion your RADIUS server (probably NPS in your case), and on the client and on the RADIUS server, not on the switch.
    It's strongly advised to move away from legacy mschapv2 as the protocol has known security weaknesses (for years already) and EAP-TLS or other EAP methods with client certificates are the most logical direction. You don't need ClearPass for EAP-TLS, you should be able to configure that with NPS as well (I know it's possible, but don't ask me how to do it). With ClearPass it's just much easier to set up and more important to troubleshoot if you have issues.
    As this is a quite radical design decision, it may be better to work with your Aruba partner, or someone familiar with this subject and your environment as it's important to get this designed properly. The switch models are less important as it's all standards based.
