Migration of APs Controlled by a VC to Aruba Central - Resolving Reassociation Issues
  • 1.  Migration of APs Controlled by a VC to Aruba Central - Resolving Reassociation Issues
    Posted May 30, 2024 12:51 PM
    I want to migrate my AP-505 and AP-515, which are currently controlled by an AP-535 as a Virtual Controller (VC), to Aruba Central. These APs have the following firmware versions: 8.6.0.16_83052, 8.9.0.2_83074, and 8.7.1.6_81786. I have registered some devices in Aruba Central, and they work correctly, but when I make any configuration changes and they reboot, the APs re-associate with the VC.
    I am also performing a parallel migration with some new devices and APs connected to the VC.
    How can I prevent these APs from associating with the VC or, if they do, how can I disconnect them so they can connect to Aruba Central?
  • 2.  RE: Migration of APs Controlled by a VC to Aruba Central - Resolving Reassociation Issues
    Posted May 30, 2024 07:36 PM
    so you have these APs running Instant mode. whether they are being managed by Aruba Central or not if they have L2 adjacency among them then they will form a Instant Cluster.so if you put them on a separate subnet then they will be their own VC and will not form an Instant Cluster among themselves.
    However for the multi-model APs to form a cluster they need to be running the exact same firmware and to have L2 adjacency.
