Hi ,
Our end customer is having cluster set up of CPPM which is running at 5.2 version. ( Publisher and Subscriber )
Presently the end customer wants to migrate the subcriber from 5.2 to 6.2.
So wanna know how to do that , following are the my queries.
1. Publisher will be on 5.2 version so if i add new VM which will be running on 6.2 version as a subscriber will all the configuration will be reflected on 6.2 ?
2. Whether i can take the backup from subscriber which running on 5.2 version and then putting that backup file on 6.2 and then adding the 6.2 as subscriber whether it will work ?
3. Have to do the configuration from scratch ?
Kindly suggest me how can i do the migration.
Nithin Kumar C V
