LS1971,
Tricky one :)
To initially associate the MSM AP with a Unified controller accross L3 boundaries, you need to use either DHCP option 43 or DNS resolution as you would for any MSM AP. Once the MSM AP has aquired its new unified firmware, it reboots and then requires a different option 43 or DNS resolution to associate.
MSM Option 43
- Option Type : 01
- Option Length : 04 or 08 or 0C or 12
- AC IP Addresses in Hex : XX XX XX XX
Hence if your AC is 192.168.1.1, the option 43 would be 01040COA80101
MSM DNS
Unified Option 43
- Option Type : 80
- Option Length : 07 or 0B or 0F or 13
- Server Type : 00 00
- Number of Addresses : 01 or 02 or 03 or 04
Hence if your AC is 192.168.1.1, the option 43 would be 800700COA80101
Unified DNS
and/or ...
depending on how new the Unified softare is.
Hope this helps,
Pete
