Migration to 8.x can't communicate with Managed Controller
  • 1.  Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 11:58 AM
    How do I change the default gateway on the managed controller?
    I tried local-config and it doesn't take the change.
    Thank you
  • 2.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 12:09 PM
    You would have to use disaster recovery mode:  https://www.arubanetworks.com/techdocs/ArubaOS_83_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/disaster-recovery.htm
    Of course if the config on the MM for that MD has the incorrect default gateway, it will be pushed back to the MD and you will lose connection again, so ensure the configuration for that MD is correct on the MM.
  • 3.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 12:21 PM
    ...aand turn of disaster recovery when it connects back again, so that it will sync with the MM.  Honestly, if you have console access to the MD, you should just do a factory reset (write erase all) and just reconnect using the full setup.  It will avoid you of having to deal with the quirks of disaster recovery.
  • 4.  RE: Migration to 8.x can't communicate with Managed Controller
    I tried in disaster recovery and get an "Error: Deleting Default Route" and the change doesn't take.
  • 5.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 12:43 PM
    Try adding the correct default gateway.
    Has the controller ever connected to the MM?  If not, just do a write erase all and run the mini setup again. Disaster recovery mode has quite a few drawbacks.
  • 6.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 12:49 PM
    I tried adding the correct default gateway and it doesn't take.  This is a new migration from 6.4.4.116 on a 7210 Mobility Controller to 8.3.0.1 and adding it to a new Virtual Mobility Master.  The migration got to 90% and then failed due to no connectivity.
    Not sure ho to run the mini setup and i don't know if the MM has all the config to pass down or how to initiate that if it does.
  • 7.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 12:56 PM
    Is this a lab or production network?
    The MM should have the entire configuration for that MD.  Please SSH into the MM and type "show configuration node-hierarchy" and see if there is an entry for the mac address of that MD.  Type cd <path to that md>  <enter>and then type "show configuration committed" to see the MD-specific configuration that MD would receive.  If that information is there, you could "write erase all" on the MD and run the full-setup to re-connect it to the MM.
  • 8.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 01:06 PM
    There isn't anything that displays if I run "show configuration committed" for the file path of the controller.
  • 9.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 01:14 PM
    Is there just an entry for that controller and no configuration?  At that level there should be minimum ip and interface configuration.
    Does your MD that you can SSH into have any configuration?
  • 10.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 01:21 PM
    I re-tried the command and here is what I got.  If I SSH into the MD it has full config from the migration.
    (ArubaMM) *[PDPHE] #cd /md/Aruba/PDPHE/00:1a:1e:04:9b:b0
    (ArubaMM) *[00:1a:1e:04:9b:b0] #show configuration committed
    location "PDPHE 1st Flr MDF"
    ip access-list eth validuserethacl
    permit any
    ip nat pool dynamic-srcnat 0.0.0.0 0.0.0.0
    controller-ip vlan 1000
    interface mgmt
    shutdown
    vlan 2
    vlan 1000
    ip default-gateway 10.100.0.1 1
    kernel coredump
    firewall
    cp-bandwidth-contract trusted-ucast 65535
    cp-bandwidth-contract trusted-mcast 3906
    cp-bandwidth-contract untrusted-ucast 9765
    cp-bandwidth-contract untrusted-mcast 3906
    cp-bandwidth-contract route 976
    cp-bandwidth-contract sessmirr 976
    cp-bandwidth-contract vrrp 512
    cp-bandwidth-contract auth 976
    cp-bandwidth-contract arp-traffic 3906
    cp-bandwidth-contract l2-other 1953
    hostname "PDPHE 7210 Controller"
    clock timezone MST -7
  • 11.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 01:25 PM
    Is that default gateway correct?
  • 12.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 01:26 PM
    Yes, it is.
  • 13.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 01:31 PM
    So did the MD obtain an incorrect default gateway?
  • 14.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 01:34 PM
    Not sure what happened in the migration.  The config came from a 3200xm controller that is going to be replaced by the 7210 and MM.  The 7210 on 6.4.4.16 was communicating just fine and the Migration Tool and worked correctly until the re-boot of the 7210 from 6.4.4.16 to 8.3.0.1.
  • 15.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 02:10 PM
    Can you type "show switches" on the MM to see if that MD checked in correctly?
    Also, if you SSH into the MD, see if the interface configuration is correct.  the 3200 has different interface naming than the 7210.
  • 16.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 02:13 PM
    It only shows itself
    (ArubaMM) *[mynode] #show switches
    All Switches
    IP Address IPv6 Address Name Location Type Model Version Status Configuration State Config Sync Time (sec) Config ID
    10.110.1.115 None ArubaMM Building1.floor1 master ArubaMM-VA 8.3.0.1_65474 up UPDATE SUCCESSFUL 0 15
    Total Switches:1
  • 17.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 02:25 PM
    So that means that the md never successfully connected to the MM.
    Is this a production network or a lab?  If it is a lab, we can try connecting the MD to the MM.
  • 18.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 02:28 PM
    Lab only, at this point.  Won't migrate licenses until new AP's are installed and config for wireless is changed.
  • 19.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 04:45 PM
    Do you have a large network and complicated configuration?  Some configurations do not survive the migration tool and it is suggested that the configuration be created manually.
  • 20.  RE: Migration to 8.x can't communicate with Managed Controller
    Posted Aug 14, 2018 06:00 PM
    Thank you for all the help!
    I worked with TAC and was able to get the default-gateway changed.  Connectivity now works.
    Sometimes its the simplest things.  I didn't realize i needed to write mem to get the gateway to change.  Who knew :)
