Migration Tool
  • 1.  Migration Tool
    Posted May 16, 2018 04:21 PM
    I am trying to migrate a 7240 on 6.4.4.11 to 8.2.0.2    I have the migration tool installed.
    My set up is Master/Stadnby, however when looking at the Migration tool, I do not see an option to Migrate Master/Standby. Only Master/Local.
    How could I go about migrating from 8.x?
    I have tried doing it in standalone but I need these controller to be part of MM and dont know how to make the conversion wiht them being MDs and not standalone as the type.
  • 2.  RE: Migration Tool
    Posted May 16, 2018 04:37 PM
    My advice:
    Don't bother with the migration tool in this circumstance.  Why?  Because you will not understand how to configure things in a meaningful way, and if you attempt to migrate a production network, you will be pressured to make things work and not understand when they dont.  To answer your question: The MM and the backup MM replace the Master and Standby hardware, except they don't terminate any access points.
    Create your MM and maybe your backup MM on a Virtual Machine.  Create a folder under MD and create your controllers and WLANs there.   This will allow you to configure everything from WLANS to interfaces on controllers without having those controllers online.
    When you are ready to migrate your 6.x controller, you will need a console cable.  Upgrade to the latest 8.2.x.x and reboot.  The console will allow you to point it at an MM.  It will register with the MM and get its entire configuration.
    That is a general overview of what you would need to do.  For specific instructions, please look at the videos in their entirety here:  https://www.youtube.com/playlist?list=PLsYGHuNuBZcatGA1POy6iVpVlDTLYzNFE before you do anything so you understand fully what you need to be effective.  It is worth staging the MMs in the lab first with a test hardware controller to understand the procedure to understand where everything is.  The migration tool is NOT a substitute for fully understanding how things are different and what you would need to do..
    Lastly, ask questions on the forum here and we will guide you through the steps in your lab, until you feel confident enough to do everything yourself.  There is quite a bit to understand, so I would migrate an active network in steps, after going through configuration in the lab...
  • 3.  RE: Migration Tool
    Posted Feb 05, 2019 05:27 PM
    I have a lab installed to test the migration from 6.x to 8.x. In my lab I have 2-virtual MMs and 2-7005 controllers. I had previously upgraded the controllers to 8.3.0.5 but now I need to downgrade them so I can test the Aruba Migration Tool for a large upgrade project that I have coming up. I am using the Migration Tool to downgrade but when I click on the 'proceed' button I think I should see a screen that would allow me to put in the controller credentials but it doesn't appear. It gives me a message that no other changes can be made and jumps right to the downgrade process that obviously fails. I am using Chrome on Windows 10 and have also tried Edge with the same results. What am I doing wrong? Also, is there an easier way to downgrade the OS other than using the Migration tool? Both partitions have a version of 8.x. Thanks for your help.
  • 4.  RE: Migration Tool
    Posted Feb 05, 2019 05:38 PM
    Steve,
    I took cj's advice and just not used the migration tool. There were so many things that would not translate over and I ended up troubleshooting strange issues with Aruba TAC. When I had to revert I lost some configs as well, luckyly form me I exported the running config and backed it up before migrating.  If you just want to go back to a bank copy of 6.x just intall in on another partition and boot from it.
