Mikrotik wireless bridge to Aruba IAP
  • 1.  Mikrotik wireless bridge to Aruba IAP
    Posted Aug 10, 2019 04:29 AM
    i've configure mikrotik to act as wireless bridge to some devices, but the instant keep blocking the mikrotik to pass dhcp to client under it. What IDS i've to disable in order to allow wireless bridge ?
    Is there any whitelist option for ARuba Instant to not blocking the mikrotik ?
    Many thanks
  • 2.  RE: Mikrotik wireless bridge to Aruba IAP
    Posted Aug 10, 2019 09:53 AM
    Does the mikrotik show up as a client on the IAP?
  • 3.  RE: Mikrotik wireless bridge to Aruba IAP
    Posted Aug 10, 2019 09:59 AM
    yup the mikrotik shows up as client and gets IP, but the ethernet interface doesn't pass through dhcp offer from wireless interface.
  • 4.  RE: Mikrotik wireless bridge to Aruba IAP
    Posted Aug 10, 2019 10:21 AM
    Try setting broadcast filtering to "none".
  • 5.  RE: Mikrotik wireless bridge to Aruba IAP
    Posted Aug 17, 2019 12:00 AM
    Disabling the broadcast filter works !
    Is there any other way to archieve this in instant without disabling broadcast filtering ?
  • 6.  RE: Mikrotik wireless bridge to Aruba IAP
    Posted Aug 17, 2019 01:36 AM
    Not that I am aware of.
