Original Message:
Sent: 11/27/2024 9:37:00 PM
Subject: RE: Mirror port only receiving a fraction of what it should
Hi Fred,
Any update on this issue. We have multiple sites with 6300m and 6200f with the same issue accross multiple firmewares. I have created a support case and hoping for fix :)
Brett
Original Message:
Sent: Oct 31, 2024 09:13 PM
Subject: Mirror port only receiving a fraction of what it should
Hello!
Unfortunately, no solution as of yet.
Fred
Original Message:
Sent: 10/31/2024 6:43:00 AM
As the last entry is from july this year -> did you got a solution?
we discovered almost the same with 10.13.1060
Original Message:
Sent: Jul 16, 2024 01:26 PM
Hello!
Unfortunately not. It is still ongoing.
Fred
Original Message:
Sent: 7/16/2024 8:15:00 AM
Hi, We're also seeing this issue on a 6200F running 10.13.1010, but to a physical IDS device. Were you able to resolve it?
Many thanks, Andy
Original Message:
Sent: May 08, 2024 05:26 PM
Hello Team!
I am facing what I believe is an issue. I have a 6200F 24 ports (+4 SFP+) with AOS-CX 10.13.1000 and configured port mirroring to 1/1/26 and 1/1/28 (SFP+). All other ports are configured as sources.
aruba6200(config-if)# show mirror 1
Mirror Session: 1
Admin Status: enable
Operation Status: enabled
Comment: SPAN port for Armis
Source: vlan rx none
Source: vlan tx none
Source: interface 1/1/1 both
Source: interface 1/1/2 both
Source: interface 1/1/3 both
Source: interface 1/1/4 both
Source: interface 1/1/5 both
Source: interface 1/1/6 both
Source: interface 1/1/8 both
Source: interface 1/1/10 both
Source: interface 1/1/11 both
Source: interface 1/1/13 both
Source: interface 1/1/14 both
Source: interface 1/1/15 both
Source: interface 1/1/16 both
Source: interface 1/1/17 both
Source: interface 1/1/18 both
Source: interface 1/1/19 both
Source: interface 1/1/20 both
Source: interface 1/1/21 both
Source: interface 1/1/22 both
Source: interface 1/1/23 both
Source: interface 1/1/24 both
Source: interface 1/1/25 both
Source: interface 1/1/27 both
Source: interface lag1 both
Destination: interface 1/1/26,1/1/28
The issue is that the destination ports are only seeing a fraction of the traffic, as confirmed by comparing the port statistics on the switch itself and watching at the receiving end, which is an Armis Collector on vSphere (virtual distributed switch). The link is between the switch and an ESXi port, not a physical switch.
sFlow is disabled on all ports.
I tried the following without luck.
- Setting the physical NIC on ESXi in direct access mode.
- Changing the destination ports, including from SFP+ to regular gigabit ethernet.
- Changing cables.
- Having only one source port.
- Running Wireshark as the destination. I am not a pro with this fish, but I see that traffic is incomplete.
- Using VLANs instead if interfaces (I have 8 VLANs)
- Using VLANs and interfaces simultaneously
- Adjusting the MTU to Jumbo Frames.
In all cases, only a subset of the data makes it through. There are no dropped packets on any involved interfaces.
What am I missing?
Thanks in advance!
Fred
