Network Management
mirroring session on 2 ports?
  • 1.  mirroring session on 2 ports?
    Posted Jul 31, 2024 01:37 PM
    hi, i have a switch HP 2530-24G-PoEP Switch (J9773A),  working for the ISP failover process
    --> In the interface 1 i have the ISP1
    --> In the interface 10 we have the ISP2
    i want to enable mirroring, the packet capture interface will be the Interface 24.
    i will put a packet analyzer on this the port 24...
    can i enable the monitoring for both interfaces at the same time? if so, what is the right syntaxis?
    thanks!
    Luis Guajardo
  • 2.  RE: mirroring session on 2 ports?
    Posted Aug 01, 2024 08:29 AM
    Have not tested with a 2530, not sure if it supports multiple mirror destinations, but on a 2930F the following seems to work:
    mirror 1 port 24
    interface 1 monitor all both mirror 1
    interface 10 monitor all both mirror 1
    Please check if it works, it may be as well that a 2530 only has 1 mirror destination and commands are simplified/different for that reason.
