Misconfiguration master discovery in IAP
  • 1.  Misconfiguration master discovery in IAP
    Posted Jul 13, 2018 11:31 PM
    Hi, we have a problem when we try to update IP Address master for discovery controller.
    In 7220 Mobility Controller menu Configuration , Wireless -> AP Instalation we update Master Controller IP Address/DNS name with new IP Address, and then we apply and reboot about 190 APs, but after reboot we realized we have a mistake when input ip address.
    And now 190 APs down in controller but they still  reachable with ping from controller. We confused how to fix configuration in each APs because the AP can't browse or remote by ssh.
    Any suggest ? or we have to reset one by one physically?
    Thank you
    Screen Shot 2018-07-14 at 10.16.43.pngScreen Shot 2018-07-14 at 10.28.13.png
  • 2.  RE: Misconfiguration master discovery in IAP
    Posted Jul 14, 2018 06:39 AM
    If you have a spare controller and you can bring it up on the wrong ip address, that is probably the easiest way to deal with it.  Or, if you have a maintenance Window and can temporarily change one of your controllers to the ip address you accidentally put in, you will have control over your access points.
    Beyond that, you have to console into each access point and fix them.
  • 3.  RE: Misconfiguration master discovery in IAP
    Posted Jul 14, 2018 11:25 AM
    Unfortunately we only have one controller.
    Thanks for your advice
  • 4.  RE: Misconfiguration master discovery in IAP
    Posted Jul 14, 2018 12:46 PM
    Is the ip address you made the mistake with reachable within your environment?
  • 5.  RE: Misconfiguration master discovery in IAP
    Posted Jul 15, 2018 12:28 AM
    It's unreachable.
    Is it possible recover with airwave?
  • 6.  RE: Misconfiguration master discovery in IAP
    Posted Jul 15, 2018 12:53 AM
    No, because Airwave configures the controller (if it is in managed mode) which consigures the access points.  If the access points do not contact the controller, Airwave cannot do anything.
    Method#1
    If you have a computer console cable for those access points, you will need to reach each AP, plug in the console, cut the power to the AP and then plug it back in.  You would then need to interrupt the boot at the console, so that you get to the apboot> prompt.  You would then type "setenv master <ip address of controller>" , "save" , "boot"
    Method#2
    Do those access points use dhcp?  If yes and you have a basic discovery method enabled (dhcp options, DNS a-record), you can (1) collect the name and ap-group info for each ap (2) do the physical hardware reset procedure on each access point, which could be faster than the console cable. (3) run the a-rename and ap-regroup commands on the commandline to put the access points in the proper group and give them the correct name.
    Method#2 detail
    - Go to the master controller and type "no paging", "show ap database long status down".  This will give you a text file all of the down access point names, their group and their mac address.  You will need that later to rename and regroup the access points after you reset them on the commandline using ap-group and ap-rename.
    - Go around to all the access points with blinking lights and execute the AP hardware button reset procedure, and allow them to boot up.
    - All the access points will appear with their mac address in the default ap-group after booting and upgrading (could take 7 minutes per ap).
    - A second administrator who is working with you could find the wired mac address of the AP in the text file and rename and change the ap-group for those access points that have been reset in the GUI.
    Please try either method with 1 access point to see which method suits you.
  • 7.  RE: Misconfiguration master discovery in IAP
    Posted Jul 15, 2018 01:14 AM
    I think we can try Method#1
    and I found this log, whats this mean
      authmgr[3909]: <522275> <ERRS> |authmgr|  User Authentication failed. username=04:bd:88:c5:c4:92 userip=10.66.18.147 usermac=04:bd:88:c5:c4:92 authmethod=VPN servername=Internal serverip=10.64.0.12 apname=N/A bssid=00:00:00:00:00:00
      authmgr[3909]: <522275> <ERRS> |authmgr|  User Authentication failed. username=04:bd:88:c5:bf:48 userip=10.66.18.23 usermac=04:bd:88:c5:bf:48 authmethod=VPN servername=Internal serverip=10.64.0.12 apname=N/A bssid=00:00:00:00:00:00
    detail log attached
    Attachment(s)
    txt
    authmgr log.txt   171 KB 1 version
  • 8.  RE: Misconfiguration master discovery in IAP
    Posted Jul 15, 2018 01:17 AM
    It almost looks like you have Control Plane Security Enabled and you do not have auto-cert allow-all enabled, so your access points cannot join.
  • 9.  RE: Misconfiguration master discovery in IAP
    Posted Jul 15, 2018 01:21 AM
    How to disable it so my access points can join ?
  • 10.  RE: Misconfiguration master discovery in IAP
    Posted Jul 15, 2018 01:36 AM
    Did you reset those access points?  If yes, they probably lost their certificates.  To allow them back on:
    config t
    control-plane-security
    auto-cert-allow-all
    write mem
    https://www.arubanetworks.com/techdocs/ArubaOS_64x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/control-plane-security.htm?Highlight=control%20plane%20security
    EDIT:
    The settings you have above should allow those access points to be able to get back on and recertifiy.
    Did you reset those access points, or did you use the console cable to change the environment variable?
  • 11.  RE: Misconfiguration master discovery in IAP
    Posted Jul 15, 2018 01:53 AM
    Some APs we reset manually, about 20 APs and the rest still as before.
  • 12.  RE: Misconfiguration master discovery in IAP
    Posted Jul 15, 2018 01:55 AM
    Did any of those access points come up, eventually?
  • 13.  RE: Misconfiguration master discovery in IAP
    Posted Jul 15, 2018 02:15 AM
    unfortunally, no one of them come back.
  • 14.  RE: Misconfiguration master discovery in IAP
    Posted Jul 15, 2018 08:00 AM
    If you don't have it, contact information for Aruba Technical Support is here : https://www.arubanetworks.com/support-services/contact-support/
