Network Management
Mismatched configuration in Airwave
  • 1.  Mismatched configuration in Airwave
    Posted Jun 27, 2017 04:25 AM
    I have 2 Instant APs in their own group, and Airwave says that the configuration is mismatched and has from the start, I believe the reason being because I made a last minute configuration change in the Virtual Controller after I had input the Airwave IP but before I had accepted them into Airwave. I have tried to delete them including the group and folder and role and user account, but when I accept them back into Airwave the mismatch persists, is there a way to fix this?
  • 2.  RE: Mismatched configuration in Airwave
    Posted Jun 27, 2017 04:29 AM
    To resovle mismatches navigate to
    • Groups>Template page and import latest template from device
    • IAP's APs/Devices>Audit page and click import settings
    • Try import setting from APs/Devices>manage page aswell, if any device specifi mismatch is there it will get resloved.
    Regards.
    Pavan
    If my post addresses your query give kudos:)
