Network Management
Missing AirWave Key
  • 1.  Missing AirWave Key
    Posted Aug 02, 2017 08:46 AM
    i have taken over the AirWave management from another employee and im trying to add another group to AirWave.
    When i get to the Admin page of the new Group its asking for an AirWave Key.
    The employee doesnt remember the key so im trying to figure out how i can find the key. By the way, there are two other groups created with the key in them but i cannot see the text of the key.
  • 2.  RE: Missing AirWave Key
    Posted Aug 02, 2017 08:52 AM
    Screen shot which you have shared with Airwave details, will show in IAP's  system>Admin page.
    Do you want to add new IAP to Aiwave or create a new group in Airwave, if you want to create a new group , login to Airwave and go to Groups tab and click create new group.
    Pavan
  • 3.  RE: Missing AirWave Key
    Posted Aug 02, 2017 09:03 AM
    the group is created but when i go to Edit for the new group and then to Instant Config then click on the System tab in the left hane column and then click the Admin tab it ask for a AirWave Key. The other groups that are created have text in the key fields.
  • 4.  RE: Missing AirWave Key
    Posted Aug 02, 2017 11:31 AM
    i have fixed the issue. I had to create the group in activate.arubanetworks.com site which them added it to the aruba management site.
