Missing APs licenses
  • 1.  Missing APs licenses
    Posted Aug 23, 2012 01:46 PM
    Hi.
    When I try the command  "show license"
    The license table is incomplete, because my key license for access point  don't show up.
    My AOS version is 5.0.3.3 this is happening in a 3200 and  a 3600 controller.
    When I run a "show license limits" the limits are Ok.
    How can I show my missing license.
    Thanks in advance.
    #3200
    #3600
  • 2.  RE: Missing APs licenses
    Posted Aug 23, 2012 01:48 PM
    Does the controller has inbuilt licenses for those APs?
    Can you post the output of command "show inventory"
  • 3.  RE: Missing APs licenses
    Posted Aug 23, 2012 02:24 PM
    Sorry I don't have access to the controller at the moment
    But I know that the 3600 controller have 4 inbuild licenses.
  • 4.  RE: Missing APs licenses
    Posted Aug 23, 2012 04:26 PM
    How many AP license mismatch do you see on the controller? It should be equal to
    Inbuilt AP license = license limit - installed license
    The Inventory should have the model number as 3200-x / 3600-y where x,y = inbuilt AP license count
  • 5.  RE: Missing APs licenses
    Posted Sep 06, 2012 09:44 PM
    Sorry but my customer is so busy , but finally here is the output for inventory.
    Supervisor Card slot            : 0
    System Serial#                  : AC000xxxx
    SC      Assembly#               : 2010031B (Rev:04.01)
    SC      Serial#                 : F0083xxxx (Date:07/11/08)
    SC      Model#                  : Aruba3600
    It says only Aruba 3600 then this controller doesn't have inbuilt licenses?
    And where may be it the missing licences.?
    thanks in advance.
  • 6.  RE: Missing APs licenses
    Posted Sep 06, 2012 09:56 PM
    You want the output of "show keys"
    A controller can only have AP licenses built in; not any of the others.
    Show keys will show you what you are working with.
