Missing Information in Arubapedia
  • 1.  Missing Information in Arubapedia
    Posted Oct 22, 2013 06:20 AM
    Dears,
    There was a lot of information related to CPPM which is now deleted. Can anyone point whether it was moved to some other page....?? Or got deleted permenatly..
    Appreciate immediate help.
    Mohammed Shiraz Mukram
  • 2.  RE: Missing Information in Arubapedia
    Posted Oct 25, 2013 02:33 PM
    It still there as far as I can tell....
  • 3.  RE: Missing Information in Arubapedia
    Posted Oct 27, 2013 02:46 AM
    Dear All,
    There might be some maintainence which was going on the Arubapedia which might be the reason for most of the articles not shown up.
    However, everything is good now..
    regards,
    Shiraz
  • 4.  RE: Missing Information in Arubapedia
    Posted Aug 15, 2017 03:51 PM
    Keep getting 403 error when trying to access Arubapedia for Partners.
    Has AFP been removed?
  • 5.  RE: Missing Information in Arubapedia
    Posted Aug 15, 2017 03:58 PM
    make sure you clear browser cache and you are hitting the homepage. Pages constanly are getting updated so you might be hitting a bad link. I just tested here and had no issues.
    https://arubapedia.arubanetworks.com/afp/index.php/Main_Page
  • 6.  RE: Missing Information in Arubapedia
    Posted Aug 16, 2017 09:40 AM
    Have done that, now I get the login screen (which didn't appear before) but still get 403 error when attempting to login using my SSO creds.
    Pash
  • 7.  RE: Missing Information in Arubapedia
    Posted Aug 16, 2017 09:57 AM
    Most partners are having this issue , I opened a case a few days ago so hopefully this will be fix soon.
    Ill update this thread once I hear back
  • 8.  RE: Missing Information in Arubapedia
    Posted Aug 16, 2017 10:41 AM
    Thanks Victor. That was my next step.
    I did email the address Tim provided but no response was given back.
  • 9.  RE: Missing Information in Arubapedia
    Posted Aug 25, 2017 11:34 AM
    Pash try accessing via this link:
    https://partner.hpe.com/group/upp-aruba/arubapedia
    It should work
  • 10.  RE: Missing Information in Arubapedia
    Posted Aug 28, 2017 09:48 AM
    Nope.
    Seems like my account is all screwed up now. I used to be able to log into the Aruba partner portal (https://partner.hpe.com/aruba), now I cannot.
    I am able to log into https://partner.hpe.com.
    Time to open a case.
    Pash
  • 11.  RE: Missing Information in Arubapedia
    Posted Aug 28, 2017 12:28 PM
    So account is back.
    Still no Arubapedia, even though I can click the link and it logs me into the partner portal, i don't see it anywhere, even if i look to "add" it as an "application". no there.
