Missing zero touch instructions
  • 1.  Missing zero touch instructions
    Posted Sep 20, 2013 11:17 AM
    Really technical issue here!!!
    I can't seem to find a copy of the RAP-2WG zero touch instructions. Can anyone point me in the right direction?
    Thanks so much
  • 2.  RE: Missing zero touch instructions
    Posted Sep 20, 2013 11:28 AM
  • 3.  RE: Missing zero touch instructions
    Posted Sep 20, 2013 11:40 AM
    I'm so rubbish at finding .  Cheers!
  • 4.  RE: Missing zero touch instructions
    Posted Sep 20, 2013 07:41 PM
    Zero-Touch configuration using Aruba Activate and AirWave is not supported on the RAP-2 or RAP-5.  It is supported on all IAPs and the new RAPs (RAP-3, RAP-10x, RAP-155).
    For the RAP-2 and RAP-5 either you pre-provision them or the end-user has to connect via wire and input the IP address of the controller to receive its' config.
    #RAP155
  • 5.  RE: Missing zero touch instructions
    answered
