Wired Intelligent Edge
Mixed Link Aggregation Groups
  • 1.  Mixed Link Aggregation Groups
    Posted Jul 22, 2019 10:28 PM
    Hi community.
    I have 02 Aruba 8400 in a VSX deployment (let´s call them SWC01-Primary and SWC02-Secondary)
    I also have 01 Aruba 3810M switch (let´s call it SRV-SWITCH) that has an important server connected to it.
    Port A1 on SRV-SWITCH is connected to port 1/9/32 on SWC01-Primary
    SWC01-Primary has lag 40 multi-chassis with port 1/9/32 assigned to it. This port 1/9/32 has a 10GE-SR transceiver installed and working
    SWC02-Secondary has lag 40 multi-chassis with port 1/9/32 assigned to it. This port 1/9/32 has no transceiver installed.
    SRV-SWITCH has a "trk1" lacp group with ports A1 and A2 assigned. Only port A1 has a 10GE-SR transceiver installed and working, A2 has no transceiver installed.
    Configurations on my switches are the following:
    SWC01-Primary:
    SWC01-Primary# sh int transceiver
    Port Type Product Serial Part
    Number Number Number
    1/9/32 SFP+SR J9150D CN93KJW7SD 1990-4635
    SWC01-Primary# sh running-config
    Current configuration:
    interface lag 40 multi-chassis
    vsx-sync vlans
    description SRV-SWITCH
    no shutdown
    no routing
    vlan trunk native 1
    vlan trunk allowed all
    lacp mode active
    interface 1/9/32
    no shutdown
    lag 40
    SWC02-Secondary:
    SWC02-Secondary# sh int transceiver
    1/9/32 SFP+SR J9150D CN93KJX1SDK 1990-4635
    SWC02-Secondary# sh running-config
    vsx-sync vlans
    no shutdown
    no routing
    vlan trunk native 1
    lacp mode active
    interface 1/9/32
    no shutdown
    lag 40
    SRV-SWITCH:
    SRV-SWITCH# sh running-config
    Running configuration:
    hostname "SRV-SWITCH"
    module 1 type jl074x
    module 2 type jl074y
    flexible-module A type JL083A
    trunk A1-A2 trk1 lacp
    ip route 0.0.0.0 0.0.0.0 192.168.100.1
    ip routing
    interface A1
    untagged vlan 1
    trunk trk1 lacp
    exit
    interface A2
    untagged vlan 1
    trunk trk1 lacp
    exit
    SRV-SWITCH> sh int transceiver
    Transceiver Technical Information:
    Product Serial Part
    Port Type Number Number Number
    A1 SFP+SR J9150D CN93KJXJMZ 1990-4635
    For this deployment I want to release the 10GE-SR transceivers that belongs to both ends of the link between SWC01-Primary and SRV-SWITCH for another use, without disrrupting the server installed on the Aruba 3810 named "SRV-SWITCH".
    For this purpose, I want to use a 3m DAC cable (J9283D) and connect it to port A2 in SRV-SWITCH and port 1/9/32 on SWC02-Secondary.
    Questions:
    In this situation, will the interface "lag 40 multi-chassis" bundle port 1/9/32 on SWC01-Primary and port 1/9/32 on SWC02-Secondary to become a 20 Gbps virtual interface?
    In this situation, will the trunk "trk1 lacp" bundle port A1 and A2 on SRV-SWITCH to become a 20 Gbps virtual interface?
    Will a link aggregation group conformed by a 10GE-SR fiber optic link and a DAC cable link work correctly?
    If this works, this will allow me to create a mixed link aggregation group (10GE-SR link + 10GE DAC cable), then replace the original 10GE-SR link with another 3m DAC cable (J9283D), releasing the 10GE-SR transceivers, all without disrrupting the server operation.
    Have anybody deployed this kind of mixed link aggregation group?
    Tnaks in advance for your support
  • 2.  RE: Mixed Link Aggregation Groups
    MVP GURU
    Posted Jul 23, 2019 11:13 AM
    It should be OK...one essential requirement for setting up a VSX LAG (or, in general, a LAG) is to use physical interfaces with the same SPEED...so 10Gbps obtained via supported SFP+ Transceivers or obtained via supported DACs should be good enough to let you to have a (VSX/non-VSX) LAG up and connected between your Aruba 8400X VSX nodes and your Aruba 3810M.
  • 3.  RE: Mixed Link Aggregation Groups
    Posted Jul 24, 2019 03:06 PM
    This is correct. LACP is working above the MAC layer and only cares on speed and duplex.
  • 4.  RE: Mixed Link Aggregation Groups
    Posted Aug 21, 2019 05:12 PM
    I used such mix media (same speed) a lot in the past, I saw no issue wih that.
