Mixing AC and N AP's
  • 1.  Mixing AC and N AP's
    Posted Apr 24, 2015 11:36 AM
    Hi:
    We have a dorm room that has an AP-115 in (roughly) every third room. This has been working OK, but there are some coverage issues, as the construction uses wire mesh in the walls.
    We want to fill in the coverage gaps by putting APs in the remaining rooms.
    We are thinking of AP-205's for the other rooms. Will this cause any problems? We're using all 20Mhz channels in the dorms, so channel bonding won't be an issue.
    Will devices go bonkers as they walk down the hall and alternate between seeing n and ac APs?
    Any other issues you've seen?
    Tony
  • 2.  RE: Mixing AC and N AP's
    Posted Apr 24, 2015 11:40 AM
    If you are mixing them in the same area, I would recommend disabling VHT in
    those areas until you completely convert the area.
  • 3.  RE: Mixing AC and N AP's
    Posted Apr 24, 2015 03:06 PM
    Tim advice is the best
    For more info read this article
    community.arubanetworks.com/t5/Technology-Blog/Removing-the-Bottleneck-in-Wireless/ba-p/77978
    Really good info in there.
    There is a point which talk about this which i paste it to you here
    - Keep access points of different phy types (a/n/ac) access points separate from each other if possible- Access points within earshot of each other that have different phy types will can provide uneven roaming.  At maximum your clients will favor 802.11n/ac access points, even though a non-802.11n/ac access point is closer and could possibly cause performance issues.  It also will make your RF less predictable.  Try to keep your deployment areas uniform to avoid such issues.
    Cheers
    Carlos
  • 4.  RE: Mixing AC and N AP's
    Posted Apr 24, 2015 04:09 PM
    That's a great post.
    Thanks!
    It says: "At maximum your clients will favor 802.11n/ac access points, even though a non-802.11n/ac access point is closer"
    That refers to n/ac and non-n/ac.
    Does it address mixing n and ac access points in the same rollout?
    I guess what I could do is move all of the 115's to one floor or section of the dorm, and use 205's on the other floors.
  • 5.  RE: Mixing AC and N AP's
    Posted Apr 24, 2015 04:13 PM
    You can mix the AP locations, but just disable VHT.
    Tim
  • 6.  RE: Mixing AC and N AP's
    Posted Apr 24, 2015 04:16 PM
    Hi Tim:
    Does disabling VHT essentiall turn off AC?
  • 7.  RE: Mixing AC and N AP's
    Posted Apr 24, 2015 04:20 PM
    That will turn off the ac practically
    It will be like a 802.11n ap.  Which is the reason of why you would be able to mix them if you disable VHT
    Cheers
    Carlos
  • 8.  RE: Mixing AC and N AP's
    Posted Apr 24, 2015 04:32 PM
    Thanks for the answer.
    Yes, I now see that the CLI guide defines the VHT option as:
    "Enable or disable support for Very High Throughput (802.11ac) on the radio."
    Thank you.
