Higher Education
last person joined: 18 days ago
Got questions on how to enable mobility in education? Submit them here!
mixing AP-224 and AP-225 within a building
  • 1.  mixing AP-224 and AP-225 within a building
    Posted Jan 05, 2015 11:12 AM
    Has anyone successfully mixed AP-225s and AP-224s within a building (or AP-214 and AP-215, etc.)? Is this advised? Would ARM adequately adjust for the differences in gain? I believe the external antennas for the AP-224 would be AIR-ANT-1B.
    We have a new building coming online and I'm told it would be easier in some areas to wall-mount APs, and in other areas of the building to ceiling-mount. Using an "L" bracket to wall mount AP-225s was met with concerns over aesthetics.
    Thanks in advance,
    Mike
    #AP225
  • 2.  RE: mixing AP-224 and AP-225 within a building
    MVP
    Posted Jan 05, 2015 11:53 AM
    We have mixed them with no issues.
    When you provision an AP-224 (or any external antenna AP) you specify the antenna gains for 2.4 & 5 GHz.
  • 3.  RE: mixing AP-224 and AP-225 within a building
    Posted Jan 05, 2015 12:17 PM
    Yes absolutely. It would just require careful RF design/planning.
  • 4.  RE: mixing AP-224 and AP-225 within a building
    Posted Jan 05, 2015 12:21 PM
    ap-ant-1f & ap-ant-1b are very similar looking but have different gain you will have to use.  Just a heads up.
  • 5.  RE: mixing AP-224 and AP-225 within a building
    Posted Jan 05, 2015 12:32 PM
    Thanks for the replies. Good to know this is possible.
    I realize one must specifiy the gain during provisioning as we actually have a number of AP-114s and 224s in the field. I was more wondering about min/max power levels and how these values translated to coverage as a function of that AP's antenna gain. Thinking about it more I'm thinking this is a non-issue as ARM adjusts rx/tx powervalues in relation to the environment.
    Mike
  • 6.  RE: mixing AP-224 and AP-225 within a building
    Posted Jan 05, 2015 12:49 PM
    Please note that the AP-ANT-1F is not indicated for use with any of the more recent AP products. It incorporates a filter that is not necessary with AP-2xx, AP-11x and other APs introduced in the last 24 months.
    When in doubt refer to the ordering guides for recommended antenna assemblies
    Example
    http://www.arubanetworks.com/pdf/products/OG_AP-210Series.pdf
