mixing instant AP-215s with instant AP-225 possible ?
  • 1.  mixing instant AP-215s with instant AP-225 possible ?
    Posted Jul 13, 2015 10:08 AM
    Is it possible to mix iap-215s with an iap-225 VC? If so, how can this be accomplished? As an additions question what about a RAP-115 with an iap-225 VC?
    #AP225
  • 2.  RE: mixing instant AP-215s with instant AP-225 possible ?
    Posted Jul 13, 2015 10:16 AM
    You can mix them.  You just have to boot the second AP up in same subnet as the first and it will join the Virtual Controller.  You must make sure that all IAPs are upgraded to the same version of code, otherwise they will not join each other.  You can do that same thing with the IAP-115.
  • 3.  RE: mixing instant AP-215s with instant AP-225 possible ?
    Posted Jul 13, 2015 11:11 AM
    Colin,
    Thank you. My IAP-225s were lower than the IAP 215 and the RAP-115 I was trying to add. I have upgraded the IAP-225 VC and it in turn upgraded the devices being added. I appreciate the super fast reply.
    Dave
