Hello!
Can I install the MM and the Airwave in the aws?
Will I still with the Aruba Support?
Thanks.
There is no official support/steps for Airwave installation on AWS. However, if you install Airwave on AWS, TAC will support the Airwave application.
There is no support for MM installation on AWS.
Thank you! Do you know if it is in a road map to provide it?
I am not sure on the raodmap of this feature. However, please check with your accounts team so that they can get the roadmap from Product Management. Also, Please open a feature request on ideas portal.
