MM has * hint
  • 1.  MM has * hint
    Posted Jul 28, 2020 09:52 AM
    I have a mm that has * hints, but I want to use tar crash, which indicates No found on this machine,why?
  • 2.  RE: MM has * hint
    MVP GURU
    Posted Jul 28, 2020 09:58 AM
    You can try to run the tar crash command at each level of the hierarchy. It may not be at the level you are currently at.
  • 3.  RE: MM has * hint
    Posted Jul 28, 2020 10:04 AM
    Type "show crashinfo".
  • 4.  RE: MM has * hint
    Posted Aug 11, 2020 07:08 AM
    The command "show switches debug"  from MM shows if crashinfo is available on any of the MM/MD's.
    Once you find the WLC with the crash, you can log in to it to run the command "tar crash"
