MM not showing AP or clients
  • 1.  MM not showing AP or clients
    Posted Jan 10, 2019 07:50 PM
    Testing 8.3 deployment with VMM and MC on same l2 subnet. AP registers with MC but do not see it on MM top display. Can update AP config from MM under controller configuration menu. Can see client under Performance but not on on Master ribbon. Have AP licenses. MC connection to VMM good. What am I missing?
  • 2.  RE: MM not showing AP or clients
    Posted Jan 10, 2019 08:55 PM
    - What version of ArubOS 8.3?
    - Can you see the controllers as up on the MM?
  • 3.  RE: MM not showing AP or clients
    Posted Jan 10, 2019 10:19 PM
    8.3.0.1
    On the top ribbon it shows 1 controllers and no APs. If I click on the controller it shows status is good.
    Sent from my iPhone
  • 4.  RE: MM not showing AP or clients
    Posted Jan 10, 2019 10:27 PM
    8.3.0.5 is out.  I would upgrade to that ASAP.
  • 5.  RE: MM not showing AP or clients
    Posted Jan 11, 2019 01:53 AM
    Upgraded VMM to 8.3.0.5 and AP now shows up. Controller upgrade comes next.
    Thanks!
    Sent from my iPhone
