  • 1.  MM-VA 8.2.1 Licensing question
    Posted Oct 25, 2018 11:35 AM
    MM master is showing the following under licensing:
    AP 66/100
    PEF 66/100
    RF Protect 66/100
    MM 78/1000
    If I want to add a new site with two controllers and 50 AP's - does it mean I would need to purchase an extra 16 AP, PEF, & RF license?
    What's the purpose of the MM licensing (1000)?
    What would happen if I add the site without purschasing anything?
    Thank you for your replies in andvance.
  • 2.  RE: MM-VA 8.2.1 Licensing question
    Posted Oct 25, 2018 11:51 AM
    That’s correct
    The MM licensing is use to manage/monitor all your Aruba Controllers and Aps
    What would happen if I add the site without purchasing anything?
    You won’t be able bring up 16 APs
    Sent from Mail for Windows 10
  • 3.  RE: MM-VA 8.2.1 Licensing question
    Posted Oct 27, 2018 03:16 AM
    Yes you need 16 more AP,PEF and RF MProtect to do this.
    De MM will count as AP+MC controllers so that will be fine with the MM-1000 license.
    When you dont get extra licenses then you can activate the new controllers but max. 34 AP will deployed
